Throttle Body Heater Gasket Repair
Old Dec 17, 2009 | 05:43 PM
jycsalas's Avatar
Default Throttle Body Heater Gasket Repair
This is the repair I did on a 2003 DII. I bypassed mine but the owner wanted the correct repair. This 2003 DII has only been service by LRNA and LRSA. I am the first untrained and un-certified person to touch this DII. It just got the full 60k mile service done a few months ago. It is in immaculate condition.....except the throttle body gasket. So....
If your throttle body heater looks like this
and you are loosing coolant, do the following repair.
This is without removing the throttle body.
1. Remove the air intake arm. Open the cap of the coolant tank to relieve pressure.
2. Order part http://www.roverparts.com/Parts/MGM000010KG.cfm
3. Remove the crank case ventilation tube
4. Depending on the position of the clamps on coolant lines going to the plate, you can remove them now or later. I could only do the driver side first.
5. Using a 5.5mm 1/4 inch drive socket, remove the two rear plate screws.
6. Disconnect and set aside the vacuum lines
7. Remove the front plate screw
8. Take a rubber glove and cut off one of the fingers and cover the vent pipe for the valve cover
9. There is a good chance that after removing the screws, the plate will still be "stuck" onto the throttle body. Take a screw driver and lightly tap the plate until it falls off. Some coolant will be dispensed and some may be under pressure.
10. Inspect the inside of the throttle body heater plate. Still think Dexcool is safe?
I used two pliers to hold the plate steady and remove the coolant lines.
11. Comparison of the new and old plate
12. Clean up everything. I used a wire brush and mild solution.
13. Clean the underside of the throttle body too
14. Install new plate and position the clamps in such a way that you can remove them easier next time.
15. Take the gasket and put a LIGHT bead of Permatex right stuff GREY. Both sides (that is what I used to seal the t-case swap and no leaks!!)
More pics
http://picasaweb.google.com/jycsalas...yHeaterRepair#
Old Dec 17, 2009 | 07:38 PM
lipadj46's Avatar
My throttle body heater plate was packed solid with crystals like that too when I did the repair. Wonder what that is all about.
Old Dec 17, 2009 | 10:01 PM
meltdowndave's Avatar
Supposedly DexCool forms reddish muck when exposed to air for extended periods of time.
My TB leaked and thought it was red RTV before I did this fix.
Anyway, I've just tore apart my engine and didn't find any evidence of additional gumming.
Change it regularly, don't let unrepaired leaks drag on, and you should be ok.
Old Dec 18, 2009 | 08:06 AM
lipadj46's Avatar
I dumped the dex and just use prestone after I did my head gaskets. I think next flush I will change to either Zerex or Motorcraft G-05 yellow coolant.
Old Dec 18, 2009 | 01:49 PM
Wolkesan's Avatar
Great write up... only thing I would add is replace those hose clamps with some worm drive clamps. Less likely to leak. Then follow Spike's advice and switch over to Peak Global LifeTime or similar coolant.
With the new gasket it should last a lot longer than the original.
Old Dec 18, 2009 | 06:08 PM
jycsalas's Avatar
That is correct... it should not have gummed up anything anywhere else except where it was exposed to air. The key is to change it regularly. in this case it wasn't changed for 60k miles.
Old Dec 18, 2009 | 06:09 PM
jycsalas's Avatar
I switched to Zerex cause they didn't have peak coolant at the store on my last flush two weeks ago.
Old Dec 18, 2009 | 06:15 PM
jycsalas's Avatar
Thanks, and I do agree with your suggestions however i want the thread to continue in discussion on the repair and not go off on "what coolant to use"
But I do recommend the worm drive clamps. i would have replaced the stock style clamps to worm drive type but I didn't have much time to do the repair and i didnt have a car to run to the store and get some.
AND like Spike, I too recommend PEAK.
Old Feb 23, 2010 | 05:23 AM
Goncho's Avatar
4th Gear
Smile Thanks for the Help!
I'm a newbee to the forum. I have an "03 Disco; had it since new. I'm trying to get my hands dirty and learn to do the repairs. This post on repairing the throttle body heater was absolutely the best instructional help I ever could have received. Now, I'm ready to do it! Thanks again, really.
Old Feb 23, 2010 | 06:16 AM
Rovin4life's Avatar
you overdid the repair as usual as a DIYer.
remove the throttle body housing four bolts, take off connector and cables and dump the thing on its side and then take it off.
alot easier and takes half as much.
