Throttle Body Heater Gasket Repair
Old Aug 2, 2011 | 04:10 PM
  #21
key421's Avatar
noob question, but whats a good sealant to buy for this job?
Old Aug 2, 2011 | 11:17 PM
  #22
jafir's Avatar
I didn't use sealant on my 99. I did this with the upper intake off and the throttle body still bolted to it. I looked at where the plate attaches and it looked ok. I'd only use sealant if I was worried about the gasket sealing for some reason.
It looks like the original posters used Permatex Grey. I use that stuff on my honda's when I'm too cheap to buy hondabond.
Old Aug 3, 2011 | 05:22 PM
  #23
KenR's Avatar
Originally Posted by Rovin4life
remove the throttle body housing four bolts, take off connector and cables and dump the thing on its side and then take it off.
alot easier and takes half as much.
Nice write-up - thanks.
I just did this job this afternoon. Took about 30 minutes, I used a very thin layer of Hondabond for the gasket sealant just because I had it, and I concur with Rovin4life's comment above; it's faster and easier to just yank the throttle body and flip it over.
Thanks again for taking the time to make this how-to.
Old Aug 3, 2011 | 07:38 PM
  #24
jafir's Avatar
I would have remove the throttle body also, but I already had the intake off.
Old Aug 4, 2011 | 06:11 PM
  #25
key421's Avatar
Okay as we all know there are two wires that connect to the heater throttle gasket, I broke the one coming from the antifreeze tank to the gasket, I don't know the name of this wire/tube anyone point me in the right direction? need it ASAP
Old Aug 4, 2011 | 06:36 PM
  #26
timdunbar's Avatar
its a coolant line, its called the "expansion tank to throttle body" line. atlantic british sells it for like 15 bucks. theres actually another one coming off the expansion tank going to the radiator might as well get that one too, if one was brittle the other one is as well.
Old Aug 4, 2011 | 08:18 PM
  #27
key421's Avatar
is this is it? Hose - Expansion Tank To Throttle Hose - Find Belts, Hoses & Other Land Rover Parts at Roverparts.com sorry im so noob.
Old Aug 4, 2011 | 09:13 PM
  #28
lordmorpheus's Avatar
That is it. Here is the other plastic tube that comes off the reservoir, that will break it you look at it wrong:
Hose - Expansion Tank To Radiator - Find Belts, Hoses & Other Land Rover Parts at Roverparts.com
Old Aug 8, 2011 | 05:21 PM
  #29
key421's Avatar
Thank you all for your help, I fixed it all on my own! Great pictures, sound advice! Love you guys and this forum! Next project, 8mm wires and +4 plat sparkplugs!
Old Aug 23, 2011 | 08:40 PM
  #30
DaveLRDII's Avatar
5th Gear
Default Thanks for this post!!
I just changed the throttle plate on my DII - Thanks for the detailed post. Took care of it in about 20 minutes.
