Tie rod ends
To check your TREs, lift the vehicle, grab the wheel real tight, and try to rock it back and forth laterally and horizontally. If there is any play, its time to replace. If not, then the TREs are still good. Sometimes the play is hard to notice, takes practice to determine if the wheel is moving or not.
Anything special with the install? I looked in the rave and it looks like I just remove the nut holding the TRE in and tap it out. Then slip the new on it. Almost seems too simple. Am I missing something?
TRE's are fairly easy to replace, they basically screw into the track rod and drag link, then you clamp them down. The RAVE directions are actually pretty good. Let us know what type you go with, and where did you find the terrafirma track rod and drag link? I was going to go with the British 4x4 ones, but I'll look into the terrafirma ones now.
Also, I have heard, but have no first-hand knowledge of it, that OEM TRE's are the best to use on our trucks. I have never used a greasable TRE, and would be concerned about snapping off the zerk when wheeling. Would someone who has used greasable TREs weigh in, and where can I find greasable TREs? I am replacing mine next weekend, and would like to order them this week.
