tierod end?????
If it is in front of the axle, it is the ball joint for the drag link. One is RH thread and one is LH thread. If you loosen the clamps holding them in the bar and turn the bar, one way makes it wider, the other makes it narrower. This is to line up the wheels with the steering wheel. I think the passenger side (right one) is RH thread. The track rod is to the rear of the front axle.
Good luck!
Jason
Good luck!
Jason
