Tightened thottle cable cruise stopped working.
Took some slack out of my throttle cable and cruise cable now my cruise doesnt work. Only other thing i did before driving it and discovering it no longer worked was disconnecting the battery and installing a new starter. Worked fine before. Pulled vac pump and checked hoses all seemed good fuses good horn still works. Any ideas?
i swaer when i looked it said 4.5-5 which i thought was to much also. Its basically in the same spot as it was when i tightened up my throttle. My cruise is a little wonky. Guess ill go tighten that up and remount my brake light
Yes it was wider in the manual, but I'm 99% certain there was a TSB especially for 03-04 with the 4.6L that said adjusting it to 1.5-2.5mm of a gap kept the CC from surging up/down when first engaged. 99-02 with the 4.0L it wasn't as noticeable. I've always set them to that gap & since cables stretch I check them regularly on my D2's. I like a smooth crisp throttle response and clean CC engagement.
