Time for a brake caliper?
Been searching. Mostly finding info on D2 brakes, but before I go throwing money, I have two questions;
1) The outside brake pad looks like new while the inside pad is down to metal... Is this a sign the caliper has gone bad?
2) Are the two bolts holding the caliper on 12mm/12 point bolts? Because I can't get anything to fit on them (and that's the ONE socket I don't have!!! HA)
Eric
Eric
No, do not order from AB, order from www.autosportsunlimited.com, $70 for a brand new DI rear caliper, not sure if you need a front or rear.
Call them Mon and ask for Chris and tell him that I sent you.
800-624-3876
I recommend replacing calipers in pairs, you dont have to but it is a good idea.
800-624-3876
I need the front. I always replace in pairs (peace of mind) I would like to swap the worn brake pad but I was unable to compress the caliper piston. I'll try tomorrow when I get the right socket to remove the caliper. Right now, when I step on the brakes, nothing happens so I think it's seized. How fast are they on shipping? Would like to get it asap. I'll park it for now.... replacing the rotor doesn't look like fun!!
Eric
Eric
I dont know how fast they are on shipping, they are on my route so I stop in and order my parts and then pick them up the next day.
But if they ship FedEx on Mon you will have them by Wed.
If they are not in stock then Thurs unless they ship from the warehouse too.
Just talk to Chris and he will let you know.
I hate to see you spend $170 per when you can get them for alot less.
The $70 ones were for the rear of my '97, not sure what the fronts will cost but I bet they will be alot cheaper than AB.
Also check www.roverlandparts.com but keep in mind that nobody is going to ship until Mon.
$76 seems almost suspicious, that's about the same price as a Cardone reman caliper from O'Reilly.
http://www.oreillyauto.com/EW3/Displ...ycleCount=1910
In any event, also replace your hub seals. Defender RTC3511 are better seals than what came on the Disco.
