Time to go Mr. Resonator.
Ok so I have decided today that I want the resonator off. But here is the thing, I read through some posts on doing it and I cant get a good visual of where to cut. I am a VERY visual person, once I see it I can do it. If anyone has a picture/digram of it that can show me the spot that would be great.
And any tips on doing it would be great as well. What should I cut with? And how long does it take? and is there anything I need to do after?
I will get a before and after vid. on here once I do it.
THANKS GUYS!
THANKS GUYS!
RE: Time to go Mr. Resonator.
Less than a minute with a sawzall....just be careful not to let it fall on you. I went to the auto parts store and bought ageneric tip to turn it down. It is bigger than the pipe, but the way I see it, it will help pull the gasses out when I am rolling.....
I'll post a pic later if you want one.....(and promise not to laugh)
http://www.youtube.com/watch?v=mMZ2964JHGg
Here you go. Took a bit to upload.
Please look around the oil stains on the driveway. I dropped the pan last weekend and made a mess...
I do apologize for the ghetto tip...
in between the resonator and the exhaust hanger. Yours is different in shape, and mineexits more to the passenger side than yours. I turned mine down a little towards the front of the truck, because if I go straight back, it would hit the trailer hitch. Yours should come straight out the back, if you want to...Not sure where the mounts are either.
I cut mine between the resonator and the farthest back mounting hanger. I left enough on each to weld it back on later if I wanted too....
