Time to go Mr. Resonator.
Old Feb 5, 2008 | 02:47 PM
Camdisco24's Avatar
Default Time to go Mr. Resonator.
Ok so I have decided today that I want the resonator off. But here is the thing, I read through some posts on doing it and I cant get a good visual of where to cut. I am a VERY visual person, once I see it I can do it. If anyone has a picture/digram of it that can show me the spot that would be great.
And any tips on doing it would be great as well. What should I cut with? And how long does it take? and is there anything I need to do after?
I will get a before and after vid. on here once I do it.
THANKS GUYS!
Old Feb 5, 2008 | 03:25 PM
okdiscoguy's Avatar
Default RE: Time to go Mr. Resonator.
I have a D1, so mine is different. Just make sure you turn it down after, or you might heat up the lights in your bumper. They will fall out...
Old Feb 5, 2008 | 03:31 PM
Camdisco24's Avatar
Is it simple to do? How long did it take you what tools did you use?
Old Feb 5, 2008 | 03:35 PM
okdiscoguy's Avatar
Less than a minute with a sawzall....just be careful not to let it fall on you. I went to the auto parts store and bought ageneric tip to turn it down. It is bigger than the pipe, but the way I see it, it will help pull the gasses out when I am rolling.....
I'll post a pic later if you want one.....(and promise not to laugh)
Old Feb 5, 2008 | 03:43 PM
Camdisco24's Avatar
Ha, that would be great, i'll try my best not to laugh!
Old Feb 5, 2008 | 04:11 PM
I cut mine with a hack saw, you may find you may want to add an extension to help vent the exhaust, I didn't but whenever I go up a hill I will sometimes smell a small amount of exhaust.
Old Feb 5, 2008 | 04:18 PM
Camdisco24's Avatar
Mike, do you have a pic of the place to cut? Or a really good description? Like i said earlier I am VERY visual. I also do want to be stupid and cut through the wrong place. Thanks! i am ready to go as soon as I know where to cut!
Old Feb 5, 2008 | 06:32 PM
okdiscoguy's Avatar
http://www.youtube.com/watch?v=mMZ2964JHGg
Here you go. Took a bit to upload.
Please look around the oil stains on the driveway. I dropped the pan last weekend and made a mess...
I do apologize for the ghetto tip...
Old Feb 5, 2008 | 06:41 PM
Camdisco24's Avatar
Thanks for that post! That gave me a perfect look at it. Is there a sepcific spot to cut, or is it just anywhere behind the resonator?
Old Feb 5, 2008 | 07:02 PM
okdiscoguy's Avatar
in between the resonator and the exhaust hanger. Yours is different in shape, and mineexits more to the passenger side than yours. I turned mine down a little towards the front of the truck, because if I go straight back, it would hit the trailer hitch. Yours should come straight out the back, if you want to...Not sure where the mounts are either.
I cut mine between the resonator and the farthest back mounting hanger. I left enough on each to weld it back on later if I wanted too....
