Tips on cleaning engine
I finished replacing the radiator and heater hoses, thermostat, and did an oil change. I would like to clean the engine now that I am done. The engine is actual pretty clean but I would still like to clean it so that it is easier to spot any leaks in the near future. If anybody has tips on the best method and cleaner to use let me know, thanks.
on
D2's love water, unless you still have the grey factory plug wires, if you do, it may misfire for a couple of minutes till they dry out.
Use cold water only, most soap solutions can and will get into your electrical connections and cause problems later on down the road.
When done, no need to wait, start the engine and go.
