Tips on cleaning engine
Old Nov 21, 2010 | 04:51 PM
buick215's Avatar
Default Tips on cleaning engine
I finished replacing the radiator and heater hoses, thermostat, and did an oil change. I would like to clean the engine now that I am done. The engine is actual pretty clean but I would still like to clean it so that it is easier to spot any leaks in the near future. If anybody has tips on the best method and cleaner to use let me know, thanks.
Old Nov 21, 2010 | 04:56 PM
DIY car wash, use their engine cleaner.
Just make sure you let it cool for 15 min before starting.
Old Nov 21, 2010 | 05:07 PM
yloDiscoII's Avatar
High pressure, cold water does surprisingly well. I cover my fuse box and ABS mod to keep any over spray from getting into the more 'sensitive' places. Simple Green is a good safe degreaser if you've got a lot of grime, don't use anything too harsh or it will eat your seals.
Old Nov 21, 2010 | 07:07 PM
buick215's Avatar
Thank for the quick reply and tips.
Old Nov 22, 2010 | 04:29 PM
buick215's Avatar
Another quick question, should I wait for the engine bay to dry before starting the engine or should I just start the engine and let the heat from the engine dry it off.
Old Nov 22, 2010 | 04:58 PM
yloDiscoII's Avatar
Let the engine heat do the work. Just be aware there might be some steam.
Old Nov 23, 2010 | 10:29 AM
D2's love water, unless you still have the grey factory plug wires, if you do, it may misfire for a couple of minutes till they dry out.
Use cold water only, most soap solutions can and will get into your electrical connections and cause problems later on down the road.
When done, no need to wait, start the engine and go.
mwohl
Aug 26, 2016 08:23 PM
alias_J
Feb 9, 2012 05:38 AM
Dan87GT
Sep 19, 2011 11:26 AM
rewi9d
Jan 16, 2011 03:23 PM
theworks001
Sep 30, 2008 02:24 AM
