Tips for watts linkage?
Old Mar 11, 2014 | 11:17 PM
MattyJ2000DiscoII's Avatar
Default Tips for watts linkage?
I'm replacing my watts linkage bushings due to a clunk. I've verified that it is in fact the linkage.
Do you have any tips for removing the 3 bolts (each side and center link)? I can jack up the car to expose the center link, and drivers side I can move the exhaust. But passenger side nut is right in front of a curve down in the frame so it's tough to get in there.
I have a 3ft breaker bar that didn't budge the nuts, and so far my impact wrench hasn't done it either (note- I have an air impact gun that needs more CFM, so i'm going to buy a bigger compressor and try again).
Just wondering what special magic has worked in the past. Longer breaker bar? Stand on the impact wrench throttle?
Old Mar 12, 2014 | 09:37 AM
ZGPhoto's Avatar
An angle grinder to remove the whole thing seemed to work for Dusty and I....
Have you soaked it in PB blaster for a few days?
Old Mar 12, 2014 | 09:45 AM
dusty1's Avatar
6" extension with swivel from the forward side. I use electric impact for that kind of junk.
advise not to back any nut/bolt all the way off with swivel on impact....ouch.
and yeah, panhard seems to drive the same on the road.....so well worth the hour and 1/2 to install conversion
Old Mar 12, 2014 | 09:53 AM
PB Blaster was on sale at the local true value, I bought 3 cans to stock up. Been soaking it daily for a week.
Dusty- I don't understand the panhard comment. What conversion?
Old Mar 12, 2014 | 09:59 AM
dusty1's Avatar
zack's thread talked me into it.
https://landroverforums.com/forum/di...version-61654/
and if your pb doesn't help...try heat. i use my plumbing butane torch. I don't buy pb.. never noticed a difference.
Old Mar 12, 2014 | 10:35 AM
Dan7's Avatar
I assume the Panhard set-up drops a few lbs over the watts. Every little bit helps on "tons-o-fun" here.
Old Mar 12, 2014 | 10:49 AM
dusty1's Avatar
Zack's prolly is a tiny bit lighter. mine is close to the same weight, but beefier and longer than watts.
Old Mar 12, 2014 | 10:55 AM
Dan7's Avatar
Hope they read the whole thread or there's gonna be some confused folks out there!
Old Mar 12, 2014 | 11:04 AM
dusty1's Avatar
Yikes, good point. Just in case they don't...
I had to cut a few inches off of mine just to fit it in there and it is hard as steel
Old Mar 12, 2014 | 11:07 AM
ZGPhoto's Avatar
Mine isn't long enough. I'm ordering a longer one online, but there is some cutting and modification involved. Hopefully the time spent underneath will pay off.
