Tire Change Help
Old May 17, 2008 | 09:03 PM
HoDiggity71's Avatar
Default Tire Change Help
Does anyone know the size of the 'center nut' of the tire. (16' wheel)
According to my Rave cd there looks to be a 'tool' located in the bag with the lug wrench, butfor what ever reasonthe previous owner failed to leave it
Thanks in advance!
02 Disco II SD
62321miles
Old May 17, 2008 | 09:11 PM
Default RE: Tire Change Help
Enlighten me, what is the center nut?
You have 5 lug nuts that you need to remove to remove the wheel and that's it. Unless you are talking about a locking lug nut.
Old May 17, 2008 | 09:25 PM
Yeah..ok
today I had all 5 lug nuts off and the tire would not come off,
so I removed the center cap and found there was a nut still holding the tire on. (so I guess i am looking at a locking lug nut)
..and looking at the picture on my Rave CD, my bag that contains the lug wrench is missing a tool that looks as if it removes this nut.
I know it's bigger that a 1 1/16' socket..just wanted to see if anyone knew the size off hand.
Old May 17, 2008 | 09:31 PM
llesra's Avatar
that big center nut doesnt hold the wheel on. dont worry about it. the wheel is probably rusted to the hub. try puting the lugs on loosely and rock the car side to side.
Old May 17, 2008 | 09:33 PM
NO! That center nut that you are talking about is the nut that holds your hub on the axle. You never need to mess with it.
Your wheel wont come off because the alloy rim is corroded and stuck to the steel hub.
You need to remove all five lug nuts, and with the tire off the ground kick it. Sit on your butt on the ground and take both feet and kick the hell out of the tire. Kick it at the bottom, it will be easier to reach.
Old May 17, 2008 | 09:49 PM
Oh...ok!
Right on..i'll be kick'in the wheel till it comes off
THANKS!
Old May 17, 2008 | 09:57 PM
http://www.roverparts.com/Parts/WM4505.cfm
You might want to get some of these, they make life easier.
Old May 18, 2008 | 10:07 AM
Mission Complete
Thanks ..Spike555
Old May 18, 2008 | 10:10 AM
Good to hear, you are welcome.
mln01
Jun 12, 2014 07:23 AM
srockrae
Dec 6, 2013 08:28 AM
collin Barrows
Aug 28, 2011 07:13 AM
treant985
Dec 27, 2010 02:51 PM
jomeheretu11
Oct 31, 2005 06:55 AM
