Tire Frustrations
ok so I have the 8J X 16 rims that have the 255/65 R16 tires. Now trying to find ones that a decent enough for on off road is a pain up here the stores have a limited selection they can get for it. Now they will only sell you the recommended ones for it as that is what they have to do but what else can I run on them?? with out replacing the rims I have..
we have stock suspension and maybe just maybe go with a 2 inch lift when I need to replace the shocks and springs later on, but for now need something that is going to work well.
Thanks
Keith
Thanks
Keith
Depends a lot on what you want from your tires and the look you are trying to achieve?
I was running 235/85 r16 which is an enormously popular size of tyre with huge selections available to meet every terrain type you are likely to encounter, look good on an 8" rim too.
I had them on stock suspension and only needed a very slight cut to the rear arch to alleviate some rub but that was all.
Wheel and tyre upgrade to 235/85 r16
I've recently upgraded to a 33X12.5X15 tyre and wheel package, going to need a bit more work on the truck to get there to work.
Fitting the 33X12.5X15 wheels and tires
Would be interesting to see what you come up with.
