Tire help.
I have a 2004 Disco with the stock rims and tires on. I want to get a new set of rims and tires that I can use exclusively for off road. Here is the catch. I don't want to drop in a new suspension yet. I like the adjustable suspension of my HSE and it works fine for now. I figure when it blows out i'll get an emu 2" or 3" lift.
So what are your recommendations. I was thinking AB 16 steel wheels? What is the max size you guys have been able to run without doing a lift? A friend has and SE with a lift and runs a 265/75/16 on AB steel. I worry this might rub.
If you think I should go another route please chime in. I'm new to this whole thing.
Hmmm....i found this neat website that allows me to do tire size calculating. Via your numbers 275/65/18 you would have a tire diameter of 32.1 inches. Can I really run a tire diameter that big? I was thinking over 30.5 was pushing it. The stock size of the 18's that i have now is 29.0 diameter.
Just my 2 cents, but I would play on the conservative size and go with 255/70-16's, maybe 265/70-16's if anyone makes that size. The formula to convert to diameter is
width x aspect ratio x 2 (then convert to inches) then add the rim diameter.
255 x .7 x 2 / 25.4 + 16 = 30.05"
Honestly the best way to do the formula is go to this site: Tire Size Calculator - Compare Tire Sizes
