Tire Inflation Question?
Old 08-26-2009, 03:20 PM
Daktari425's Avatar
Default Tire Inflation Question?
I just installed a new set of Yokohama Geolandar 255/55/R18 tires on my 2004 Discovery. The dealer inflated the tires to 32 lbs. I noticed that the maximum inflation for the tires is 50lbs. There seems to be a variance of opinions as to what is preferred since the vehicle is heavier that the average SUV. I will only use the vehicle for highway or in town use and want the tires to wear evenly. Thanks!
Old 08-26-2009, 03:40 PM
discoxd's Avatar
around 40 is what i run... the higher the pressure the less rolling resistance thus better gas mileage, but i rougher ride, less air pressure and you ride like your on marshmallows but its kills your MPG... most important thing is to make sure both front and both rear have exactly the same, this will keep from causing unneeded wear on your diffs and keep the vehicle from pulling to one side while you drive...
Old 08-26-2009, 03:41 PM
... so what is the question? what PSI should you use?
Old 08-26-2009, 04:40 PM
AK Rover's Avatar
I agree with discoxd, 40-45 is best for mileage but gives a slightly rougher ride. I ran 45 in my tires. As long as the tires on an axle are at the same pressure they don't have to be the same front and rear. I don't know about the D2 but D1s call for 26 front and 36 rear on the door sticker. The higher pressure in the rear is to compensate for heavier loads. Since the transfer case is essentially an open differential and allows the driveshafts to turn at different speeds you can run the different tire pressure front to rear.
Old 08-26-2009, 04:45 PM
hazletbassist89's Avatar
we have a lot of rough roads in my town so I run about 30 psi in each, but when I get my lift and new tires I'll probably push it closer to 40.
Old 08-26-2009, 04:54 PM
StevenDiscoII's Avatar
Originally Posted by AK Rover
.......... 26 front and 36 rear on the door sticker......
AK, D2 also calls for 26 PSI in the front, which I have found way too low. Most of the time I run 32 front and 42 rear.
Old 08-26-2009, 05:49 PM
Look in the drivers door jam for Rovers thoughts, you will see the rear is around 38.
Run 40 all the way around for better wear and gas mileage.
Old 08-26-2009, 07:34 PM
I run 35 front and 40 rear.
Old 08-26-2009, 07:58 PM
Daktari425's Avatar
Default Tire Pressure
Thanks for all the information on tire inflation! I will most likely go with 40 lbs all around. The tires look like they need air but I guess I am not used to the 18" wheels. I just replace me 16" rims yesterday!
Old 08-26-2009, 08:53 PM
AK Rover's Avatar
Why would you get rid of 16" rims for 18"? Most go the other way. I'm curious how much difference there is in ride quality.
Quick Reply: Tire Inflation Question?
