tire pressure ?
Old Mar 30, 2008 | 10:55 AM
utunes's Avatar
4wd High
Default tire pressure ?
Hi, i have a question about the tire pressure. I have the original 18" rims with the goodyear wranglers on my 00 Disco II. Yesterday i checked my pressures and the front had 24 psi, the back had 28 (right) psi and 30 psi (left)
the car almost never has any extra weight besides 1-4 people
can u please tell me to what should i inflate them to?
Old Mar 30, 2008 | 11:19 AM
jdelp's Avatar
Default RE: tire pressure ?
With no extra weight I usually run 28psi in the front and 38-40psi in the rear. The manual says up to 46psi in the rear, but unless you're towing or have alot of cargo it just causes too stiff a ride.
[align=left] [/align]
Old Mar 30, 2008 | 11:30 AM
Open your drivers door and on the pillar is a sticker that tells you all you need to know about your tires.
Old Mar 30, 2008 | 11:46 AM
35 in the front, 40 in the rear will give you better wear and gas mileage.
Old Mar 30, 2008 | 12:14 PM
utunes's Avatar
4wd High
with 28 psi my back tires look pretty full, i am scared that with 40 psi i might blow them up
Old Mar 30, 2008 | 12:32 PM
You don't your eye to determine the exact tire pressure for a tire. Check and fill the tires as suggested, only when cold, then check every other month.
oncorhynchus
Jan 21, 2007 02:14 PM
lpx
Jan 15, 2007 06:57 AM
agavrilo
Nov 16, 2006 12:19 AM
T3LU_03
Jun 8, 2006 03:18 PM
kensei
Jan 1, 2005 09:01 AM
