Tire pressure question.
Old Feb 5, 2008 | 01:47 PM
bigugly82's Avatar
Default Tire pressure question.
I'm running General Grabber AT2's, size 245/75/16 (if memory serves me). Mostly on road. The MAX Pressure for the tire is 80PSI. When I installed them they pumbed them to 40PSI. What does everyone recommend for on-road and then light trail/off-road pressures?
Thanks
-Ugly
Old Feb 5, 2008 | 04:15 PM
Default RE: Tire pressure question.
35 t0 45 #'s is a good place. They are a 10 ply rated tie and will ride hard if you put too much air in.
Old Feb 5, 2008 | 04:40 PM
bigugly82's Avatar
right on, thanks Mike. I was wondering about the ride aspect too.
-Ug
Old Feb 5, 2008 | 05:26 PM
jkid's Avatar
TireLoad CapacityWeight on Tire (GAWR/2)
------------------ x -------------------------
Max. Tire Psi x
Solve for x.
I think that the load on the tire and psi are directly proportionate, so this is the equation that I always use and it seems to work fine. The only estimate is forthe weight on the tire, so I use the GAWR and take a few pounds out becauseI rarely have the vehicle fully loaded. Take about 50% out for offroad use (maybe not 50%, I would just eyeball it for that because it depends on the terrain, speed, etc).
0304Disco
Dec 6, 2012 01:44 PM
lpx
Jan 15, 2007 06:57 AM
agavrilo
Nov 16, 2006 12:19 AM
T3LU_03
Jun 8, 2006 03:18 PM
kensei
Jan 1, 2005 09:01 AM
