Tire PSI
I'm at 40 front / 42 rear. They look a little squishy, but ride nice.
Try them at 35psi for a week. Then try them around 40psi.
If you are running 8 or 10 ply tires, 35 to 40 all the way around is perfect considering our factory tires were rated as a 2 ply passenger tire. 60 pounds, besides beating you to death will wear the center tread off the tire.
Also, you can air them down to 18 pounds of pressure when off road with the exception of 18" tires and you really don't want to go under 24 pounds or you can cut the side walls out of them in the rocks.
