Tires!!
Old Jan 17, 2014 | 03:09 PM
augustwillo's Avatar
Default Tires!!
Looking for some tires. 255/65/16. My 2 front are BALD!
Old Jan 18, 2014 | 12:42 AM
Discovery-4.0's Avatar
8th Gear
Not sure if you are looking for new or used, but I would recommend going to a 245/75/16 which will fit fine stock, will fill the fender wells more and look good.
I prefer a m/t but if you want an all terrain I would suggest Kenda Klever. They run about $128 per tire and have free shipping. If you are looking for used, if you have not all ready, might I suggest craigslist. A lot of places that sell used tires will advertise on there. You can also go here: Best Used Tires They have free shipping and a large selection of used tires. I have used them in the past without issue before I bought a new set of tires.
Old Jan 22, 2014 | 09:19 AM
With the 245/75/16, can I use my current wheels? Also what is "m/t"? Thank you for your time!
- used or new.
Old Jan 22, 2014 | 09:32 AM
drowssap's Avatar
try emailing paul grant he usually has a bunch of tires and wheels for sale
Old Jan 22, 2014 | 10:40 AM
Dane!'s Avatar
245/75r16 will rub, I have had them on my stock D2 and they cut a hole in the bumper, they will only not rub if he has a non-sagging front end. I'd just get the stock size tire, if you will be using this as a DD and road use only, I'd suggest Michelin's, super quiet, very long lasting (80-90,000 Mile warranty) and good for a tiny extra mpg, I still use mine on an extra set of wheels.
Old Feb 13, 2014 | 05:27 PM
hk9176251's Avatar
Check your pm. I think I can help you out!
Old Feb 13, 2014 | 05:37 PM
Dan7's Avatar
Go with stock diameter anyway...no rubbing or speedometer issues. Cheapest AT tires (if you're interested...looks good on a Disco!) are Maxxis 751 Bravo AT from e-bay. ATs are a nice compromise between the noise/wear of an MT and the quiet/efficiency of street tires.
Old Feb 13, 2014 | 05:45 PM
etsZac's Avatar
Originally Posted by Discovery-4.0
Not sure if you are looking for new or used, but I would recommend going to a 245/75/16 which will fit fine stock, will fill the fender wells more and look good. I prefer a m/t but if you want an all terrain I would suggest Kenda Klever. They run about $128 per tire and have free shipping. If you are looking for used, if you have not all ready, might I suggest craigslist. A lot of places that sell used tires will advertise on there. You can also go here: Best Used Tires They have free shipping and a large selection of used tires. I have used them in the past without issue before I bought a new set of tires.
Unless there are multiple versions of the Kenda Klever it's definitely a MT not an AT, I have them on my disco and they are knobby and howl loudly on the highway.
Old Feb 14, 2014 | 05:29 AM
hk9176251's Avatar
The speedo won't be that far off my 285/75/16 tires are 1 mph off per 10 eg. 30 is really 33mph 60
is really 66 mph I checked with a gps speedo app on my phone
Old Feb 14, 2014 | 08:59 AM
taylor15's Avatar
Having the speedo off by 10% is a lot. I would have that calibrated to work with the new tires
