Tires - Why do most recommend 245's?
Old Mar 18, 2008 | 09:34 AM
humroot's Avatar
Default Tires - Why do most recommend 245's?
Just curious why most folks here recommend 245/75-16 tires for the DII? I am looking at new tires for my stock DII and was wondering why the thinner 245 are the choice tire. What about 265/70-16? A little thicker, but only 1.5" bigger in diameter than stock and close to the same as the 245's. So is 245/70-16 size a good choice for a stock DII?
Old Mar 18, 2008 | 09:46 AM
Default RE: Tires - Why do most recommend 245's?
245/ 75 or 245/70 are about the biggest tire size you can go to with out a lift.
You won't squeeze a set of 265's under a tired factory suspension that has already settled an inch or more since new.
Besides, going to a 265 will cost you just short of 2 MPG.
Old Mar 18, 2008 | 10:09 AM
WolfPack's Avatar
I'll vouch for that! I upgraded from the stock 235/75s on my Blazer to 265/70s and lost a bit more than 2 mpg. A bit shocking at first, but it makes sense.
Old Mar 18, 2008 | 11:02 AM
I went and changed out my gears, going to 4:11's to help bring back my power and mileage, since I wasn't going to switch back to a smaller tire. My mileage and power are back and I still have the height and traction I wanted off road.
Old Mar 18, 2008 | 11:33 AM
WolfPack's Avatar
Yea that's next on my list! I'm saving up for a bit though because I wanna put in a locker in the rear when I re-gear. Also I gotta fix some front suspension stuff on it, I've got a sagging torsion bar and a blown CV, so she's not seeing much offroading for a few weeks
Old Mar 18, 2008 | 11:35 AM
A sagging torsion bar, Disco's don't have torsion bars. Which one is sagging and as for the CV joint, if it is bad, I hope you are not driving it, will cost you more when all hell lets loose.
Old Mar 18, 2008 | 11:39 AM
WolfPack's Avatar
No I meant on my blazer, and it's the passenger side t-bar and passenger side CV. Not being driven, I'm showing the Range Rover a little more love while the Blazer waits for $$
Old Mar 18, 2008 | 12:06 PM
Darover's Avatar
I've been experimenting quite a bit lately. I too have gone from stock suspension to a 2 inch lift and 265/70-16, and found that driving in sport mode helps the vehicle up to speed and therefore allows better m.p.g with oversize tires.
It makes sense, since except from a complete stop where the stock gears are just what they are, the sport mode allows higher r.p.mtransmission upshift which acts the same as if the gears were lower. Try it it works!!! Only if you have bigger than stock tires though.
Old Mar 18, 2008 | 02:12 PM
humroot's Avatar
How about 255/70-16? Same width, but only 1" bigger all around. Would they work? Plus, they are cheaper than the 245's.
Old Mar 18, 2008 | 02:42 PM
Darover's Avatar
Yes, these would fit without a lift. Too small if you decide to upgrade to an aftermarket suspension though.
