Tocking sound when cold????
Old Nov 21, 2008 | 12:38 PM
kfx4001442's Avatar
Default Tocking sound when cold????
2000 Disco II 95,000miles. I have noticed that when the engine is cold I hear this low very rythmic tocking sound upon acceleration. I do not her the noise when just idleing nor do I hear it after the engine is warmed up. Any ideas what what is going on?
Old Nov 21, 2008 | 02:01 PM
sloppyjoe's Avatar
Default RE: Tocking sound when cold????
worse case is a bad crank bearing but more likely is is a simple exhaust leak. once the exhaust metal heats and expands it goes away.
Old Nov 21, 2008 | 02:38 PM
NiteTrain's Avatar
next time you start it up cold step outside the rover and see if you can tell if the noise is coming from the top of the engine or the bottom
Old Nov 21, 2008 | 03:24 PM
Switzer's Avatar
Rover engines are reliable but not high tech. The rocker arms and flat tappet camshaft makes for a noisy engine when cold. I let mine warm up for a minute before I drive it in the morning. When the engine is cold start it up and listen for where the noise is coming from.
Cheers,
Pete
Old Nov 21, 2008 | 04:35 PM
Your are going to need to be a lot more specific as to the location of the noise.
mattmo78
Nov 21, 2013 01:23 PM
pkppunk
Jan 26, 2013 07:05 PM
hhalimi
Feb 3, 2012 05:46 PM
mvjimenez
Jun 12, 2010 10:25 AM
aldenplanthire
Jan 22, 2005 08:15 AM
