Tom Woods installed, now vibration...
Old Mar 1, 2009 | 10:59 PM
Disco Fuego's Avatar
Default Tom Woods installed, now vibration...
So I installed the Tom Woods front driveshaft yesterday and went to visit some friends. I noticed that I have vibration as of 70-75 mph now, which I did not have before... Could it be that the shaft is not balanced correctly? Or did I miss something during the install?
Also, when I had the old shaft removed, I was able to turn the differential by about 3/8" as well as the transfer case by the same distance. Is that normal? When I drained the front diff last weekend, I noticed a substantial amount of shavings and now I am a bit worried it may be going bad.
Cheers!
Old Mar 1, 2009 | 11:32 PM
Jupiter Rover's Avatar
Are the bolts tight?
Is your CDL locked?
What kind of shaft did you get? Double cardon? Two joint? multi?
When I took my drive shaft out it also turned a little bit. Same thing as when you jack up one tire and you can spin the wheel just a couple inches.
Old Mar 1, 2009 | 11:43 PM
Bolts as tight as I could get them, no movement in them.
CDL not locked
Double Cardon
Ok, so the movement is normal, that is good to know.
Old Mar 1, 2009 | 11:59 PM
discoboy's Avatar
A few months ago I had my front driveshaft replaced with a rebuilt from a local indy. I too noticed a vibration afterwards, turns out the replacement shaft needed to be balanced. Has been ever since.
Old Mar 2, 2009 | 12:34 AM
Yeah, my next guess is a balance.
Old Mar 2, 2009 | 07:03 AM
All I can say is that every single person on here who has installed a Tom Woods has had to get it balanced because of a vibration after install.
Old Mar 2, 2009 | 07:34 AM
jycsalas's Avatar
Spike555:
That is why i am rebuilding mine one my own.
Old Mar 2, 2009 | 07:43 AM
okdiscoguy's Avatar
You will still need to have it balanced at a shop. You are adding 3 grease zerk, and while it may not seem like much, it will throw it off....
Old Mar 2, 2009 | 07:59 AM
jycsalas's Avatar
But where I live you can't get passed 50mph before having to brake hard or you'll end up in the ocean... so I should still be vibration free. I will stagger the grease fittings and go from there. MUCH cheaper than buying Tom Woods and STILL having to get it balanced.
Old Mar 2, 2009 | 08:01 AM
okdiscoguy's Avatar
They don't charge very much to do it. I had both shafts done and balanced for $150. They had fittings, but at 160K miles, I just wanted to make sure.
