Too much oil?
Old Jul 30, 2009 | 10:16 AM
03WhiteDisco's Avatar
Default Too much oil?
I'm afraid after an oil change I just received they put maybe a quarter or half a quart too much oil in it. Is it bad to drive it this way? Thanks
Old Jul 30, 2009 | 10:41 AM
tornado_735's Avatar
Yes. Have them fix it at their expense.
Old Jul 30, 2009 | 10:57 AM
DiscoJag's Avatar
Wink Too much oil
I agree. I would rather be half a quart low than half a quart over. I can't swear to it, but it might cause something to leak (a seal or gasket) that wouldn't otherwise, and with a Land Rover you certainly don't need anything to assist in causing oil leaks.
Old Jul 30, 2009 | 02:00 PM
I wouldnt worry about it.
2 qts over yes, 1 qt no.
Old Jul 30, 2009 | 10:23 PM
oljohnboy's Avatar
i feel that that little over will not negatively affect your engine. But being as **** as I am, i would probably get some out via oil filter (cliche?) hell, you can just loosen it and loose 1/4 qt. then tighten back. but tornado is right, they should fix at their expense, but i hate oil change places!
Old Jul 30, 2009 | 10:29 PM
sloppyjoe's Avatar
a qt or more over i would be concerned,,,
a half i would not worry a wink
Old Jul 31, 2009 | 09:36 AM
When cold and sitting on level ground, exactly where is the oil on your dip stick?
asulil
Sep 24, 2013 07:41 PM
Aj6543
Nov 10, 2010 10:41 PM
began
Nov 23, 2008 08:59 AM
Kraftyz51
Oct 21, 2007 10:25 AM
tap121
Apr 10, 2007 07:35 PM
