Took the valve covers off...how bad is this?
Old May 21, 2019 | 02:23 PM
Brandon318's Avatar
Default Took the valve covers off...how bad is this?
The truck has 150k on it, not sure how diligent the PO was about oil changes. Does this look normal for 150?
Old May 21, 2019 | 02:29 PM
Best4x4's Avatar
I’ve seen much much much much worse!
Old May 21, 2019 | 02:33 PM
CollieRover's Avatar
Just make sure all the oil passages are clear. Maybe do a few quick oil changes? I don't know.
Old May 21, 2019 | 02:37 PM
mollusc's Avatar
one of mine looked like it had sand in it, there was so much burned oil. that's clean as a whistle by comparison.
Old May 21, 2019 | 03:16 PM
Richard Gallant's Avatar
Looks good to me - but the oil passages are the big thing
Old May 21, 2019 | 03:58 PM
Lisa Bunch's Avatar
Mine were worse. Remove the rocker shafts, spray with oven cleaner, scrub clean. Make sure the rockers move easily - shift them over and use a scotch brite on the shaft. Use a hose nozzle to clean passages in the rocker shafts. Blow dry and coat with engine oil. use a wire on the oil passages in the block to make sure they are clear. Reinstall properly.
Old May 21, 2019 | 05:33 PM
Brandon318's Avatar
I'm a wee bit concerned because the little metal spacers that are embedded in the valve cover gasket were missing on both sides on the rear outboard corners, and I couldn't find them anywhere in the head or valley. Think it's possible they were omitted on purpose by a previous mechanic?
Old May 21, 2019 | 06:24 PM
Typically they show up in the oil pan
Old May 21, 2019 | 06:42 PM
shanechevelle's Avatar
Do not put that back together until you find them.
Old May 21, 2019 | 08:43 PM
Brandon318's Avatar
Literally they are no where to be found.
