Torque Converter Access Plug
Old Apr 24, 2014 | 03:02 PM
primussucks's Avatar
Default Torque Converter Access Plug
So I'm missing the access plugs that cover the torque converter (see first pic #30).
My question is, how can I get all the crud out of there? Been in quite a bit of mud, snow, dust lately and think I need to clean it out. Can I open up the hole in pic #2 without loosing all my tranny fluid? I'm suspecting no.
Secondly, does anyone know where to order some replacement plugs? Otherwise I'll just cover with duct tape.
Thanks
Attached Thumbnails Torque Converter Access Plug-screen-shot-2014-04-24-2.50.26-pm.jpg   Torque Converter Access Plug-hole.jpg
Old Apr 24, 2014 | 03:21 PM
Jared9220's Avatar
Yes, you can take that cover off. It is an inspection cover and there should be no fluid in the bell housing.
As for those plugs. Here you go. Oil Pan Grommet (Rear) (Genuine Part # ) - Land Rover gaskets and seals from Atlantic British
Old Apr 24, 2014 | 03:27 PM
Thanks Jared...
I get there should be nothing in there, but how to do I clean it out, as it has been exposed to everything from dirt, dust, mud, snow (all 4 of those in the last 3 weeks).
Wow... damn.. $6 for a piece of rubber, i might just go the duct tape route.
Old Apr 24, 2014 | 03:41 PM
Jared9220's Avatar
Originally Posted by primussucks
Thanks Jared...
I would take off that bottom inspection cover first and visually see how bad it looks up in there. If it looks really bad then you could always take a hose and spray water in where those rubber plugs go. Water has been getting in there the whole time anyway so I don't think it would hurt anything. You could always spray it out with air afterwards to help dry it out.
Old Apr 24, 2014 | 04:00 PM
Is that indeed an inspection plate or will all my fluid drain out?
Old Apr 24, 2014 | 04:24 PM
Jared9220's Avatar
I'm 95% sure that is an inspection hole cover to look at the flywheel. We are talking about the circle cover with 3 small bolts, right? Give me a few minutes to confirm this.
Old Apr 24, 2014 | 04:28 PM
ralphobell's Avatar
I believe so as well, there is no gasket for that cover. The only way your going to loose fluid is if you drop the pan or disconnect a line.
Disclaimer: I'm not a professional mechanic but I did stay in a Holiday Inn Express last night.
Old Apr 24, 2014 | 04:33 PM
ralphobell's Avatar
Sorry I was wrong, there is a gasket there. So know I'm not as sure as I was.
Old Apr 24, 2014 | 04:36 PM
Jared9220's Avatar
I'll go pull mine off right now and let you know what happens. I'm pretty sure that those 2 rubber plugs and the gasket on the inspection cover are to help keep stuff out of the bell housing in fluid in.
