Torque Converter Access Plug
Old Apr 24, 2014 | 04:38 PM
ralphobell's Avatar
Ok, now that I have studied it a little more, you might get some leakage when you open that plate. But you shouldn't get a lot of oil coming from there. See this thread. His is missing but fluid is not coming out of it while using it.
https://landroverforums.com/forum/di...n-plate-40570/
Old Apr 24, 2014 | 05:07 PM
Jared9220's Avatar
I just pulled that cover off and had no problems/no fluid came out.
Old Apr 24, 2014 | 06:18 PM
primussucks's Avatar
Awesome. Thanks Jared. I think I'll take the plate off and run the hose through the inspection holes. Let it drip dry and "seal" it up with some duct tape.
Thanks guys!!
Old Apr 24, 2014 | 06:52 PM
Jared9220's Avatar
Thanks guys!!
you are welcome.
I would just spend the $12 and get 2 new plugs. I would hate for duct tape to get sucked into that hole get wrapped up in something and mess something up.
Also, I have been missing one of those plugs ever since I bought the truck and everything looked really clean in there. I don't know how much mud you get into, but if it looks pretty clean in there then I wouldn't even mess with the water. Just my 2 cents
Old Apr 24, 2014 | 10:09 PM
ScreamingLife's Avatar
I'm glad this thread came about. I've been missing that piece since I took the engine out.
Old Apr 25, 2014 | 02:30 PM
LMAO... I just took the inspection plate off and this is what I found.
Knocked it all loose (and out)... Felt around in the inside and there was definitely sand and dirt in there... i'm thinking i'll run the hose through it.
Old Apr 25, 2014 | 02:37 PM
ralphobell's Avatar
Now that my friend is AWESOME! Anything living in there?
Old Apr 25, 2014 | 02:38 PM
Jared9220's Avatar
I've never seen anything like that before. That bell housing is packed full of mud. You are lucky you haven't got a rock in the flywheel and broke it all to hell.
Old Apr 25, 2014 | 03:13 PM
Dan7's Avatar
That inspection plate will leak if your RMS is bad...as me how I know
Old Apr 25, 2014 | 06:54 PM
marizcal's Avatar
you can pulled out without problem.. I take out the one of my Disco and there is nothing that could spill out.. just an inspection hole...
