torque converter wont seat!! need help
I realize this is an old post, but just had this exact issue on my '03 today and thought I would post what worked for me after having my *** kicked by this. Spent 20 minutes trying to reseat the converter with no luck at all. Eventually noticed that the stator inside the converter moves around a fairly significant amount. Whenever I would tilt the converter up to mate it to the input shaft, the stator would drop maybe 1-2mm and make it impossible to line everything up.
I ended up standing the trans up on the tail end and the converter went right it, in 5 seconds or less.
Hope this helps if someone else runs across this thread in a search. Seems some people have no problem with it, but if you do this method might be helpful.
