torque converter wont seat!! need help
Old Dec 28, 2009 | 03:03 AM
03discoman's Avatar
Default torque converter wont seat!! need help
hey guys,
i am having a beitch of a time installing my torque converter!! no matter what i cant get the thing to seat to the pump...
whats the trick
Old Dec 28, 2009 | 08:47 AM
Scott R's Avatar
How do you mean? Did you bolt the TQ to the flywheel first and are attempting to stab into it? Or it won't slide on the input shaft of the transmission?
Old Dec 28, 2009 | 10:42 AM
03discoman's Avatar
engine is out and im exchanging the fluid in the tranny and TC ..so i'm just trying to get it back onto the tranny side.... i donno what i'm doing wrong.. it wont line up with the pump!!
Old Dec 28, 2009 | 03:21 PM
Scott R's Avatar
I just did this a few weeks ago and I only had to wiggle it a little to get it though the splines, but really no resistance installing it.
Old Oct 25, 2014 | 07:11 PM
Kenso's Avatar
I realize this is an old post, but just had this exact issue on my '03 today and thought I would post what worked for me after having my *** kicked by this. Spent 20 minutes trying to reseat the converter with no luck at all. Eventually noticed that the stator inside the converter moves around a fairly significant amount. Whenever I would tilt the converter up to mate it to the input shaft, the stator would drop maybe 1-2mm and make it impossible to line everything up.
I ended up standing the trans up on the tail end and the converter went right it, in 5 seconds or less.
Hope this helps if someone else runs across this thread in a search. Seems some people have no problem with it, but if you do this method might be helpful.
Old Oct 25, 2014 | 07:31 PM
MetalMarine's Avatar
well since the original poster never commented if he got it on or not. he might still be working on it. lol.
and thank you for posting fix
RANDY04D2
Aug 19, 2014 08:48 AM
cobbcj7
Apr 12, 2014 06:57 PM
fj60disco
May 18, 2010 10:34 PM
kraelo
Apr 1, 2008 12:02 AM
jared
Dec 20, 2007 06:51 AM
