tow what do I owe this pleasure ?
Hi Again,
So I bought a used LR hitch for the 03 Disco ..... big bugger and a 2" rec.
So having towed bugger all in the past, does anyone have any advice or do
they know the hitch capacity? It bolted on to the underside of the frame
with two bolts and then two meaty bars back to each of the the spring bolts,
one in each end and two more bolts on the other end of the bars to the hitch.
Looks pretty tough, also any suggestions on how to wire up a set of trailer lights?
Cheers'
Dave
Cheers'
Dave
Here is your wiring.
Land Rover Trailer Wiring Kit (Same Fit As Genuine Part # HIL-734)
The load limit for the Disco in the US is 5,500lbs. with a 500lb tongue weight limit.
In the rest of the world it is 7,000lbs.
scdsteffes
10-06-2011 09:21 AM
