towing
Old Jan 2, 2009 | 10:51 PM
03disco2's Avatar
Default towing
i need to k=hook up my 03 disco 2 with towing to tow the max with brakes and want to do it right don't know what it has on it other than the receiver i know i need wires
Old Jan 3, 2009 | 07:14 AM
AK Rover's Avatar
Default RE: towing
Get the trailer wiring harness from Atlantic British that plugs directly in to the factory socket inside, behind the passenger side tail light. That will give you a 4-flat connector so you'll need to go to any auto parts store and get an adapter to go from the 4-flat to 7-round. Rovers come standard with a battery charge line already run so the only wire you will need to run from the front of the truck is the signal from the brake controller to the trailer plug. I am actually in the process of wiring up my D1 right now, hope to be done today. I'll post some pictures as I get it done.
Old Jan 3, 2009 | 08:30 AM
Default RE: towing
The standard Rover conversion package, doesn't, I believe, come set up for brakes.
I would look up a good trailor shop, pick the brake package you want based on your needs and have them wire it up for you. Do not go to U-haul.
Old Jan 3, 2009 | 08:34 AM
AK Rover's Avatar
Default RE: towing
The Rover does not come equipped for trailer brakes so that will have to be wired in. Everything else is a simple plug and play operation if you use the adapter from AB.
Old Jan 3, 2009 | 03:27 PM
Default RE: towing
http://landroverparts.us/LandRoverAc...erTrailer.html
RobFrey1
Oct 14, 2005 12:14 PM
brossnaeh
Oct 7, 2005 09:51 PM
Benhamtroll
Jul 22, 2005 12:31 AM
sixpack
Jul 5, 2005 04:41 AM
listed
Jun 12, 2005 06:57 AM
