Towing with Disco I
Old Jul 16, 2008 | 10:06 AM
GeoC's Avatar
Default Towing with Disco I
My 97 Disco I manual gives a max towing weight in hi range as 5500 lbs. It also states that max tongue weight is 330 lbs. Something is not quite right here because towing the max trailer wt at max tongue wt gives you only 6% of the trailer wt as the tongue wt, that's too low a % to be safe on the hwy. A safe tongue wt % would be in the range of 10-15%. I am thinking that the problem with the low max tongue wt is a result of the dinky looking hitch. (I friend of mine's 96 D1 cracked a weld on his hitch!) Question: is anyone aware of another hitch that is available or has anyone out there fabricated one for a D1 that can take a higher max tongue wt? I think the obvious answer is that the D1 realisticly can only safely tow a trailer weighing max of about 3500 lbs. Thoughts or comments?
Old Jul 16, 2008 | 04:39 PM
Default RE: Towing with Disco I
They can tow a 5500 # trailor but you are limited to a 350# tongue weight.
Old Jul 16, 2008 | 08:21 PM
NiteTrain's Avatar
you can load the trailer so the bulk of the weight is over the trailer tires and towards the back of the trailer to keep weight off the tongue.
Old Jul 17, 2008 | 05:26 PM
GeoC's Avatar
Exactly, but that's a recipe for disaster. Hit any kind of bump at freeway speed and the forces at play can completely unload the tow vehicle's rear axle. Add a touch of brake and you will find your trailer pushing the rear of the tow vehicle around. Result: all of a sudden you can find yourself sideways on the freeway. It's a very common mishap and it happens suddenly. That is why tongue wt as a % of trailer wt is so important. I want everyone to be safe out there as well as the folks that happen to be sharing the hwy with you.
Old Jul 17, 2008 | 06:11 PM
The trick is to not go to fast. Load most of the weight just in front of the trailer axle whenever possible. You want some weight on the tougne but not to much.
And if your driving so fast that you cannot control the vehicle under any circumstance then you are going to fast.
Old Jul 17, 2008 | 07:19 PM
NiteTrain's Avatar
too far forward or too far towards the rear are neither good..I try to get most of the weight over the trailer axles when I tow. make sure your trailer brakes are in good working order.
gruehle
Aug 7, 2008 04:36 PM
dirtymorgan
May 7, 2008 08:10 PM
mc_eyes
Apr 29, 2008 05:27 PM
boyofcows2
Feb 18, 2007 04:16 PM
Benhamtroll
Jul 22, 2005 12:31 AM
