Towing light flashing with tone!
I think there is still confusion here about just which indicator lamp is illuminated.
The OP says "it is the green light n the upper L hand corner of the dash." The indicators in the upper LH corner are Service Engine Soon, Hill Descent Control, Brake, Diff Lock, T-case Neutral and Traction Control.
The only one of those that's green is Hill Descent Control, and if the HDC button is pressed when the T-case is not in Low the light will flash and a warning will chime continuously.
Try pressing the HDC switch and read p.49 of the owners manual.
Trailer warning lamp should illuminate with the direction indicator warning lamps and hazard warning lamps when trailer attached.
03discoman
01-14-2010 09:11 AM
