Trailer brake control & 4 Pin to 7 Pind adaptor
Hello All,
1. I figure there are people on here that have done a lot more towing than me. I did some searches but didn't see a definitive answer on the question.
I am looking to connect a Agility proportional brake controller to a 7 pin trailer connector. I already have the AB adapter for the 4 pin flat connector. If I buy this: Will this all work.
Adapter 4 Pole to 7 Pole and 4 Pole
Adapter 4 Pole to 7 Pole and 4 Pole w/Test Lamps Curt Wiring C57674
2. Next Question. Where do I tap in to the brake wiring to run the Agility brake controller up front in the drivers foot well.
Agility? Proportional Brake Control w/plug in connector
The adapter you used was the same one I used.
Mine just had Hopkins name on it instead of Curt......
milehighwonder
08-01-2012 03:48 PM
