Trailer harness
Trailer harness
My 04 Disco2 trailer harness is not in the right/passenger side tail light(U.S model). Not in the left one either.
I looked underneathe, and there it is on the driver side, without enough slack to have came from the tail light either. Seems factory, as no wires are hacked.
I just thought it was strange, because everything I've read says it should have came factory inside the passenger tail light.
Is there anywhere to buy a harness to connect to a standard 4 pin trailer harness, without electric brakes?
The couple of harnesses I have seen are $100-$120!
And it didn't specify if they had electric brakes, and if so, if they came with the adapter to the 4 pin.
I know LR parts are expensive, but $100+ for a wiring harness is ridiculous. I don't want to cut/splice anything either if at all possible, just plug it in and go.
I'll only be pulling a 4'x6' open trailer with a 4wheeler or mower on rare occasion.
Does anyone have any advice on what or where to buy?
Thank you
Trying to load pictures now
Thank you
I just read where the plug I have in the pictures above is actually for a rear parking distance sensor, an option my 04 SE doesn't have.
But, there is still no extra plug or harness inside/behind either tail light. Only the factory harness coming through the body, and going only to tail light bulb sockets.
Nothing elses.
Nothing elses.
This is what I did years ago to get a 4 pin trailer harness.
Go here
https://discoweb.org/oldsite/
Select "tech" at the top of the page.
Than scroll down on the left side to "Trailer Wire disco2".
Go here
Sixpack577 (08-18-2017)
Sixpack577 (08-19-2017)
I did this last weekend. My trailer wiring was behind the right tail light. I cut and spliced four wires for the harness.
Ground: Black
Left Turn Signal: Green With Red Stripe
Marker or run lights: Red with Black Stripe or Red with Orange Stripe
Right Turn signal: Green with light blue stripe
Brake: Green with Purple stripe
I just used a generic 4 flat connector like:
https://www.etrailer.com/Wiring/Hopkins/HM48110.html
I think it was $7 at oreillys.
Uhaul allowed it, worked for brake lights and turn signals.
Ground: Black
