Trailer wiring
I have an '03 with the Land Rover trailer wiring.
the terminals are corroded so I'm going to rebuild/modify the housing to hold an American style flat plug. Does anyone know which wire goes to which function? I couldn't find it on the RAVE CD.
Pin 1 - Yellow LTurn/Brake
Pin 2 - Blue - Empty
Pin 3 - White Ground
Pin 4 - Green RTurn/Brake
Pin 5 - Empty
Pin 6 - Orange Reverse
Pin 7 - Brown Taillights
This link helped me out alot also... http://www.marksrv.com/wiring.htm
Pin 5 - Empty
The damaged piece is the part that mounts to the truck - where you would plug the above mentioned adapter in to. The damage from it being full of water is bad enough that one of the pins no longer has power.
I could replace the terminals, but since I only use the 4 flat plugs I figured I'd just install one of them.
gruehle
Jul 27, 2020 09:10 AM
bcolins
Aug 6, 2015 08:38 AM
