Tranny Gear Selector Interlock Solenoid Help
Old Mar 26, 2013 | 07:12 PM
MONEYMIKE's Avatar
Default Tranny Gear Selector Interlock Solenoid Help
I have re-installed my center console, I took apart center console so I access my cdl. so, everything is re-installed and the thing is that the transmission gear selector interlock solenoid is not unlocking ....so, I cant get it out of park..... unless I push it in. My question is, does the solenoid need to be reset? because I did unplug to get to the cdl. if i can reset how should i reset this solenoid?
PICS OF SOLENOID BELOW
Attached Thumbnails Tranny Gear Selector Interlock Solenoid Help-image.jpg   Tranny Gear Selector Interlock Solenoid Help-image-2-.jpg
Old Mar 26, 2013 | 11:44 PM
acamato's Avatar
Are your brake lights working?
Old Mar 26, 2013 | 11:46 PM
MONEYMIKE's Avatar
Do you mean the e-brake light or on gear selector light?
Old Mar 27, 2013 | 12:04 AM
MONEYMIKE's Avatar
Are you talking about the brake light switch?
Old Mar 27, 2013 | 01:03 AM
You may also have distrurbed the attached connector, which is a ground header. There is a short wire to frame ground near the connector. Also check fuse 25 under dash.
File Type: pdf
File Type: pdf
Old Mar 27, 2013 | 07:17 AM
drowssap's Avatar
have you checked for power at the solenoid?
Old Mar 27, 2013 | 07:29 AM
MONEYMIKE's Avatar
How do you check the power of the solenoid
Old Mar 27, 2013 | 07:38 AM
drowssap's Avatar
do you own at 12-volt test light? if so here ia a utube video on how to use it
acamato's Avatar
The interlock works off the brake light switch, one of the first things I would check is to make sure your rear brake lights are working. If they are then check for power at the solenoid (when the brake pedal is pressed). You will need a meter or test light to do that.
Old Mar 27, 2013 | 02:00 PM
MONEYMIKE's Avatar
Well its not the brake light switch .. Becuz lights are workin
