Tranny temp Light Disco 1
Old Feb 5, 2010 | 05:22 PM
oljohnboy's Avatar
Default Tranny temp Light Disco 1
Well, I got off work today, it is raining badly, started the truck, and the tranny temp light was on immediately. Checked the fluid, it is fine, it does need changing, but the fluid was not hot. I sat for an hour waiting for the light to go off, it never did so I drove home. I think I have a faulty sensor, but I don't know where it is. Can anyone tell me where it is located, and other possible things to check? I called Land Rover, they said the tranny does not have a filter. Any advice is appreciated!
Old Feb 5, 2010 | 06:18 PM
okdiscoguy's Avatar
pretty sure the trans oil temp sensor is on the cooling lines by the radiator. Should be by the ps pump
You do have a filter
Old Feb 5, 2010 | 09:33 PM
oljohnboy's Avatar
I thought so! The dealer near me seems pretty bad at blowing things out of proportion. I do see a sensor on a metal cooling line going into the radiator. It looks perfectly dry, but I'm going to investigate more tomorrow. Is there any other way to see if the tranny is actually overheating?
Old Feb 5, 2010 | 10:01 PM
The only way to see if the trans is actually overheating is with your wifes meat thermometer.
If the light is coming on as soon as you start the truck after sitting overnight my money is on a bad temp sensor.
Old Feb 5, 2010 | 10:15 PM
oljohnboy's Avatar
Where do you want me to stick the thermometer?? That's sounds dirty......
I could grab the stick with my hand, the fluid was a little warmer than body temp. That was after running at temp for 10 minutes when I pulled over at the auto parts place. Oh, and it doesn't just come on once you start it, it comes on when you turn the ignition to on, before it starts.
Old Feb 5, 2010 | 10:20 PM
Transmissions warm up quick, you cant go by feel.
You would need to stick the temp probe into the dipstick tube and actually get it into the trans fluid, thats a long ways.
How much is the sensor?
If you think its cheap just replace it.
Otherwise you are looking at a trip to a mechanic to have the actual trans temp checked which will prob cost more than the sensor.
Old Feb 5, 2010 | 10:32 PM
oljohnboy's Avatar
I haven't found the replacement yet so I don't know if it is cheap. It ought to be.
Old Feb 6, 2010 | 06:46 AM
Have you checked Rovers North or Atlantic British?
Old Feb 6, 2010 | 06:58 AM
AK Rover's Avatar
There's no way that the tranny could be overheating at startup after sitting for a long time. This definitely sounds like a faulty sensor. Looking at the picture it appears the sensor screws into the side of the transmission but I'm too lazy at the moment to verify that in the RAVE manual.
http://www.roverparts.com/Parts/AMR4948.cfm
Old Feb 6, 2010 | 10:32 AM
oljohnboy's Avatar
well found the temp sensor on drivers side, behind radiator near power steering lines off reservoir. Ohmed out sensor, it is closed circuit so the sensor is shot. Thanks everyone!
