Trans fluid help!!
Trans fluid help!!
Hey folks! I have poured over other post and am not sure I am finding the answer.
the last couple days the out door temp has been about 80* and my trans temp light came on. So I came here and google searched the forum and found most post said low fluid or defective temp sensors.
I have have only owned this about a mont and never have had the light before, so I went and got a few qts and was prepared ( so I thought) too top it off.
I drove it around a bit till the light came back on. I used my laser thermometer and at the highest reading on the pan I got was about 120 to 180. The cats registered about 400.
parked on all fours I crawled underneath after running through the gears for about five seconds and went to remove the fill plug. I was surprised when it gushed out and not stopping. I lost roughly 5 cups of fluid.
I had it running while doing this so I don't know what could be wrong. It drives and shifts fine. Call me confused.
please help.
please help.
Ewan (04-16-2019)
Some D2's can also have a temp sensor installed on the Transfer Case. I believe it's in series with the unit on the transmission though so it could be either unit that is getting hot. I've certainly seen my fair share of burnt up TC's from lack of lubricant. I've only seen one HP22/24 burn up and that was when the case blew apart from a drive shaft failure. With that amount of transmission fluid coming out I'd bet my money on the TC unless the AT fluid was black & burnt smelling from lack of being serviced.
HuskerRover (04-10-2019)
