Trans fluid help!!
Old 04-10-2019 | 07:29 PM
HuskerRover's Avatar
The cooler trans temp was the key. I let it get up to about 100 and no more gush. Thank you!
Old 04-10-2019 | 07:37 PM
Best4x4's Avatar
What color is the fluid?? Does it smell burnt??
Old 04-10-2019 | 07:44 PM
It did not seem that bad, however I have ordered a filter and gasket to replace once it gets here next weekend.
Old 04-10-2019 | 07:59 PM
Best4x4's Avatar
I'd certainly check the TC while your down there. Then you can mark Trans & TC upkeep complete
HuskerRover (04-10-2019)
Old 04-10-2019 | 08:32 PM
I tried every 1/2" tool I have, ratchets, wobble extensions, breaker bars. Nothing I have will fit in thae space tonight. Tomorrow on the way home I am going to pick up a serpentine belt tool. I think that will be perfect for this with the slight clearance given.
Old 04-11-2019 | 12:59 AM
Richard Gallant's Avatar
Yea that T-case filler is in a brutal space for sure, I need to check and top mine off it leaks
Old 04-15-2019 | 08:03 PM
Small update.
I drained and filled the TC. Ended up using a serpentine belt tool for the best result of removal.
It warmed up outside again to about 77, the light retuned after about 7 mi of 50 mph driving. I disconnected the tc sender and it remained on. I guess it's the one on the front cooler. I will have to wait until it goes on again and disconnect that one for certainty. My trans filter etc should be arriving soon for fluid replacement.
I guess as if the removed trans fluid doesn't smell burnt, the trans should be ok? Just a faulty sensor?
Old 04-15-2019 | 08:10 PM
Best4x4's Avatar
Could be wiring, or the sensor. Filter job isn’t bad, but just have something wide for it to drain into.
Popsickle
05-30-2013 07:56 AM
SDinDS
09-18-2010 03:27 PM
Jupe209
08-29-2010 11:29 AM
lhgdale
12-28-2008 08:38 PM
skyguy
01-17-2008 09:29 AM
Quick Reply: Trans fluid help!!
