Trans fluid help!!
I tried every 1/2" tool I have, ratchets, wobble extensions, breaker bars. Nothing I have will fit in thae space tonight. Tomorrow on the way home I am going to pick up a serpentine belt tool. I think that will be perfect for this with the slight clearance given.
Small update.
I drained and filled the TC. Ended up using a serpentine belt tool for the best result of removal.
It warmed up outside again to about 77, the light retuned after about 7 mi of 50 mph driving. I disconnected the tc sender and it remained on. I guess it's the one on the front cooler. I will have to wait until it goes on again and disconnect that one for certainty. My trans filter etc should be arriving soon for fluid replacement.
I guess as if the removed trans fluid doesn't smell burnt, the trans should be ok? Just a faulty sensor?
