Trans Temp Light
on
RE: Trans Temp Light
ORIGINAL: ch4699
2000 Disco II. tmep light is on, but it is the trans temp light. Vehicle seems to run fine and does not over heat. Any ideas on what the problem could be...
check the two small connections coming off the sensor on the drivers side of the transferbox (yes t-box) for corrosion and water this will cause the light to illumate. i have also replaced the transmission sensor in the cooler due to incorrect signal. so doin't think the worst first.
all the best
all the best
