Trans Temp Light
Old Dec 28, 2007 | 12:10 PM
ch4699's Avatar
7th Gear
Default Trans Temp Light
2000 Disco II. tmep light is on, but it is the trans temp light. Vehicle seems to run fine and does not over heat. Any ideas on what the problem could be...
Old Dec 28, 2007 | 12:18 PM
S4poor's Avatar
Default RE: Trans Temp Light
Vehicle wouldn't over heat due to the tranny light. Your tranny would. I would not drive it until it is checked by a competent person.
Blown tranny = serious cash.
Old Dec 28, 2007 | 12:23 PM
ch4699's Avatar
7th Gear
Thanks for the quick reply...I will have it looked at....
Old Dec 28, 2007 | 12:37 PM
S4poor's Avatar
ORIGINAL: ch4699
You're welcome.
zerochills's Avatar
my trans. temp light came on once when my wife was driving it, accidently had it in sport mode for the entire day. Let it cool and took it out of sport mode and have not had a problem since
Old Dec 28, 2007 | 03:27 PM
Sport mode won't cause it to overheat, all that feature does is change the shift points based on your throttle pressure.
Old Dec 28, 2007 | 03:29 PM
ORIGINAL: ch4699
When does it come on, is it own when you first start up your truck or when, how is it shifting and when did you last check and service your tranny's fluids?
Old Dec 31, 2007 | 07:40 AM
ch4699's Avatar
7th Gear
comes on as soon as the engine is started.....
Old Dec 31, 2007 | 08:40 AM
raid13's Avatar
check the two small connections coming off the sensor on the drivers side of the transferbox (yes t-box) for corrosion and water this will cause the light to illumate. i have also replaced the transmission sensor in the cooler due to incorrect signal. so doin't think the worst first.
all the best
Old Dec 31, 2007 | 09:05 AM
ch4699's Avatar
7th Gear
Thanks for all the info.....Happy New Year
