transfer case carnage!
well, that's what was goin through my head when my disco broke down.
i was in the city, turning onto a downhill street, when i heard an awful metal banging sound. i continued down the hill until i could pull over safely. i stopped at a stop sign and then stepped on the accelerate to pull over but the truck wouldn't move!!!!! I moved the transfer case shifter into high and low gear and nothing! i locked the center diff into high and to my surprise, the truck moved. so i limped to work which was 2 blocks away. i didnt drive faster than 5mph. after work i called a tow truck andgot the disco home safely.
the next day i took off the transfer case cover plate, expecting total carnage, and it looked normal. i think it was just low on fluid because it didn't look like 4pints came out of the transfer case when i drained it.
so now i want ur advice. i think if i refill the transfer case it should be okay, but i dont want to refill it and have to open up the case again because that didnt solve the problem.
on
I would say something in your driveline broke, if the front broke and was spinning free no power would be transfered to the back til you locked the diff. In anyway I dont think low fluid would do that, it would cause things to wear out an overheat but not stop working just cause its low. I would check your front and rear diffs.
on
the transfer case works just like the front and rear diffs, if one tire slips all the power is transfered there. same in the transfer case, if one drive shaft is turning freely, either because of a part broke or a tire spinning, all the power goes there. the diff lock locks the diff in the transfer case so both driveshafts spin at the same rate, so when you're offroad and a tire spins you still have power in the end opposite the spinning tire. hope this helps.
tunernewb92
11-19-2009 10:36 PM
VFib-911
11-10-2009 02:41 AM
