Transfer Case Extremely HARD to shift..
Old 10-02-2008, 03:52 PM
discoandaboat's Avatar
Default Transfer Case Extremely HARD to shift..
As in I feel like in going to break the handle going from H to L. Even when I push hard into L the "dont not put in gear light" flashes on the dash. It yours real hard to put into gear??
Ive tried in N stopped
Ive tried in N roling about 3mph all with the same result.
Is this caused by the shifter mechanism or the transfer case itself?
Old 10-02-2008, 05:29 PM
Default RE: Transfer Case Extremely HARD to shift..
Unless the transfer case is low on fluid it is the shifter. When was the last time you shifted into low range?
Old 10-02-2008, 05:55 PM
Just serviced the transfer case 2 months ago with new fluid. I actually got it into L last week but i remember it being a pain.
Old 10-02-2008, 06:40 PM
The more you use the lever the better it will shift. You need to use it once a month to keep it working well.
If you only use it once or twice a year it will give you fits.
Old 10-02-2008, 06:41 PM
What year and model, this will help?
Old 10-02-2008, 07:04 PM
This is the guy with the '03 that eats oil.
Old 10-02-2008, 10:14 PM
yes thats me oil eating non shiftin SOB
Old 10-03-2008, 04:29 PM
What ever you do, don't force the shift, go have someone look at it.
Old 10-03-2008, 04:37 PM
The shifter on the transfer case is a use it or lose it type of thing. It needs to be "exercised" once a month.
Old 10-04-2008, 12:57 AM
Switzer's Avatar
After installing my CDL handle it took several off road trips and over 100 miles of driving with the T-case locked (dirt roads only) before it would engage. The T-case is splash lubricated, so moving those parts around means they all get a little oil.
Cheers,
Pete
Quick Reply: Transfer Case Extremely HARD to shift..
