Transfer case issue
Transfer case issue
During our recent trip I thought the usual noise from the truck seemed to have a slightly different sound, but only while it was in motion. My best guess was the sound was coming from either the front or the transmission area. Just got a chance to check it out. I jacked all 4 wheels off the ground and checked the hubs which seemed fine. Both driveshafts were rebuilt recently and also seemed fine. I let it idle and put it in D. The rear axle seemed normal but the front wheel(s) was barely turning and then completely stopped. Looking under I could see the front driveshaft was not turning either. The T-case has done almost 200K and the T-case oil was changed a few thousand miles ago. A few questions:
1. Other than replacing the T-case, is there anything else to check?
2. Should I dismatle and try to repair my T-case or just replace it with a used or rebuilt unit?
3. Thoughts on putting some limited (less than 100) street and highway miles before I replace/repair it?
Any thoughts or opinions are appreciated.
With the car still up on stands I locked the center diff and everything looks like it it is operating normally with both axles turning. I could not hear the noise (very subtle, maybe like a bearing going bad?) I heard previously. I did try having my wife drive(slowly!) around a large parking lot while I crouched on the rock sliders on both side as well as the front bumper and still couldn't hear the noise. The wife thinks I may be hearing things. What are the sounds of a CV joint going bad?
I do appreciate the help. I should have realized that without the center diff locked that one of the axles wouldn't receive power.
Usually, the first signs of a C/V joint going bad...is a popping noise while turning, full lock (steering wheel turned hard/held in one direction).
Me, l'd pull front shaft and see if that changes anything. Nowadays, recently rebuilt or replaced...means nothing to me. Do you feel any unusual movement in output and input yokes of transfer and axles?
You really didn't give a good description of noise, just said it sounds different. So, knowing if it is a rotational noise (changes with speed), whining noise or slight grinding, happens more while turning, happens at one speed more than another or is constant...might give us a better clue.
Trans fluid been checked recently?
mollusc (06-25-2021)
