transfer case/transmission/prop shaft issue
Old Dec 5, 2010 | 03:46 PM
nopicknj's Avatar
Cool transfer case/transmission/prop shaft issue
Wife's Disco. Front driveshaft failure. Knocked hole in tranny. Good Times! Removed shaft. Transfer case and tranny in neatral to get it home. Pulled trans. pan to inspect. No visable damage other than cracked case. Dropped valve body and disconnected wires. Put pan back and towed to a welder that specializes in aluminum. Did an amazing job. Got it home, re-installed valve body, pan, fluid, new prop shaft. Put 4 quarts DexIII back in. No leaks! Now put transfer case in H and tranny in N. Then park, rev., drive. Car acts like it wants to go forward in all gears except park. Slips. No reverse. No service lights. I'm thinking front differential or trasfer case or transmission itself. Did I miss something or did more damage occur than I thought?
Old Dec 5, 2010 | 03:58 PM
mwindth's Avatar
First of all, WOW!!!
Second of all, pics please.
Third of all, the next time I see any poster asking "if they should" replace the front u-joints and centering ball...I'm referring them to this post.
Good luck man and keep us posted.
Old Dec 5, 2010 | 05:10 PM
While the truck in drive have your wife try and move it forward while you lay on the ground next to it (out of the way of course) and see which if any of the 2 prop shafts spin.
That will tell you if you have a bad tranny or diff.
Old Dec 6, 2010 | 07:24 AM
nopicknj's Avatar
Wow! She's destined to get the insurance money at this rate. Thanks I'll try that.
Old Dec 6, 2010 | 07:36 AM
Also, if you only put in 4 quarts of fluid you may be burning up your tranny, do you know how to fill our tranny?
the420star
Aug 6, 2015 12:08 AM
Kenso
Oct 28, 2014 09:05 PM
MjrWraith
Aug 18, 2014 03:29 PM
powderhound
Jul 7, 2014 10:51 AM
2rovers
Jul 30, 2013 11:08 AM
