Transmission?????
Old Mar 8, 2007 | 11:35 PM
tbriska's Avatar
Default Transmission?????
While driving the past few days, I have noticed that when going over 20mph and I take my foot of the gas for a moment, then press the gas again it sounds like a big clunk in the gears shifting. Could this be the trans downshifting and upshifting? It is pretty lloud, the click. it does not do it from a standstill just while moving. 2003 disco./ What could this be????
Old Mar 9, 2007 | 11:42 AM
98roverguy's Avatar
Default RE: Transmission?????
How many miles you have? Almost sounds more like a driveshaft/u joint problem. When was the last time your changed your fluid?
Old Mar 9, 2007 | 12:21 PM
Aquaholic's Avatar
It sounds like regular driveline lash. If you're not used to full time 4wd it may seem excessive.
Old Mar 9, 2007 | 03:27 PM
tbriska's Avatar
It has 29000 on it. I never changed fluid, but stilln under factory warranty so I assume it was done reg. Just got it a month ago. Could there be some looseness in the shaft?
Old Mar 9, 2007 | 10:14 PM
Elhoff's Avatar
The Discos all have some amount of backlash in the drive line at those speeds. Whether this is excessive is hard to say?
