Transmission Cooler Lines - where to buy?
Old Aug 11, 2022 | 02:18 PM
Fallstaff's Avatar
Default Transmission Cooler Lines - where to buy?
Hi Gang,
My transmission oil cooler lines are shot. But I'm having a hell of a time finding where to buy them. Most of my usual places (lrdirect, John Craddok, Rimmer Bros) all seem to not carry them any more.
Asked a mechanic to see if he could manufacture them, but he didn't think it possible.
Anyone have a line on these things? Or have some clever way of getting around the lack of parts?
I'm starting to think they're going to be the death of the truck at this point (that and the half dozen other things that need help).
Old Aug 11, 2022 | 02:37 PM
jastutte's Avatar
i don't see why a hydraulic hose shop couldn't fab those up if you could bring in the old ones.
Old Aug 11, 2022 | 02:38 PM
zski128's Avatar
The steel part is shot or the rubber and connector part? If just the rubber/connector part any hydraulic shop should be able to repair it. Most NAPA parts stores in my area can do this.
Old Aug 11, 2022 | 03:53 PM
Fallstaff's Avatar
Hmmm. This is a path to go down.
i don’t think napa in Canada do this but I like the idea.
having never had need for hydraulics I didn’t know my local hydraulics shop or really how to find one.
Anyone know where to go in Toronto? Or even what to google?
Thanks!
Old Aug 11, 2022 | 10:12 PM
ahab's Avatar
Try googling hydraulic shop Toronto. If the "quick release" fittings (which at this point are anything but) are shot you may need to bring in the cooler itself for them to work up a retrofit. I see this as a win in the long run however. Those crappy fittings are diabolical and only ever benefited the dealer when under warranty. By now most are rusted to the point of being a huge PITA to deal with, wasting valuable time for anyone having to disconnect them. Some here have come up with a workaround using high pressure hose and clamp, you can try searching that out as well. Those fittings annoy the hell out of me.
Old Aug 12, 2022 | 11:39 AM
whowa004's Avatar
There is a fix for the disconnect ends that works extremely well. I've replaced both trans and oil cooler connectors one my white d2 a few years ago and have had zero issues.
Amazon Amazon
Amazon Amazon
will need to sand down the cooler fittings slightly for the swagelok fittings to slide on but it's quick and easy as the coolers are aluminum.
Old Aug 12, 2022 | 12:17 PM
ahab's Avatar
Looks like a great solution, Have you taken them on and off? Do they still seal after repeated use?
Old Aug 12, 2022 | 12:36 PM
whowa004's Avatar
I have not taken them on and off more than maybe once with zero issues. I don't see why there would be any issues however. The uniform pressure of the swagelok's should seal perfect every time and you can't really crush or harm the cooler side unless not fully seated or crooked somehow.
Old Aug 12, 2022 | 12:48 PM
ahab's Avatar
I'm not surprised to hear it, just curious how the aluminum stood up to any repeated use. With any luck they won't ever have to come back off more than maybe once.
Old Aug 12, 2022 | 01:10 PM
whowa004's Avatar
Could always pull hose off the barb end if worried about the aluminum but I'd be more worried about yanking the cooler arms trying to get hose on or off more than the fitting attaching to coolers.
