Transmission Cooling line questions
Old Nov 15, 2014 | 12:32 PM
NoogaRover's Avatar
Default Transmission Cooling line questions
Hey Guys, just finished up replacing my radiator and after getting everything buttoned back up I noticed the tranny cooler line on the drivers side is leaking (leaking in the swivel area of the "quick" connector). Few questions, 1. does anyone know of an "easy" fix for this, least temporary until I get to question 2. Question 2. this is the big one, I believe I have decided to go with braided lines so does anyone know the thread count/size I need to connect back at the tranny and the size for the "quick" connect on the cooler itself. I know I can order the braided lines, but where and how do I go about the connectors. Thanks in advance!
Old Nov 15, 2014 | 12:55 PM
discobass's Avatar
4th Gear
Funny you should mention this I replaced my rad, water pump, thermostat and coolant last weekend. I took the truck for a drive about 3 hours later the same line your are talking about leaked all of the trans fluid out leaving me stranded on the highway, but a tow to a buddys house, and then drained the remaining trans oil left, filled it back up and presto. I think when I re-fitted all the lines I didn't make sure the locking sleeve was properly fitted, so just make sure to double check. But if in doubt replace the line, but I have been told it a PITA to get it of the top of the trans, good luck!
Old Nov 15, 2014 | 01:08 PM
NoogaRover's Avatar
Talking
I just got this link from another Forum, here it is in all of its glory. check it out if your leak problem pops up again. P. T. Schram Rover Repair, Indiana's Finest Land Rover repair service
Old Nov 15, 2014 | 05:47 PM
discobass's Avatar
4th Gear
Great idea, but mine leaks from the fitting to the cooler itself.
Attached Thumbnails Transmission Cooling line questions-10673d1339828240-upper-oil-cooler-hose-leak-connection-oil-leak.jpg
Old Nov 15, 2014 | 05:56 PM
Shade Tree's Avatar
Looks to me like the line is not pushed in far enough. But even if you do that it still might leak. Those things are a pain, odd ball size tubing.. 7/16" or metricated something or other.
Old Nov 15, 2014 | 11:53 PM
NoogaRover's Avatar
Yea the pics on the site dont show the cooler connection for the rubber hose version but the braided lines show the connection to the cooler. Big difference in price but if it saves me the headache of wrangling the whole line out i may go with it. Dunno if you've looked back at the tranny where that line connects.....any fix that can bypass diggin into that is A OK in my book. Also your connections are super clean compared to mine and others i've seen. Like shadetree said it may just not be seated all the way
Old Apr 3, 2015 | 12:47 AM
Tony Luna's Avatar
EXACTLY what happened to me tonight after doing the exact same repairs. Driver's side line spewed all the fluid out at the coupling to the cooler. I'm having the truck towed back home tomorrow so I can dig into it again.
Old Apr 3, 2015 | 09:53 AM
NoogaRover's Avatar
Be sure its seated correctly. Since your saying its spewing it may not be, mine didnt spray i just had a small leak after reconnecting. After cutting it out i found the swivel part of the connector had rusted and failed. Sadly i never got my hands on the part from the other post. Ended up replacing the entire line. And it is a pain in the ***. Tranny has to come down to get to the top connection.
Old Apr 3, 2015 | 01:31 PM
Motorhead1's Avatar
Im just curious Nooga, is your avatar a picture of you?
Old Apr 3, 2015 | 02:24 PM
NoogaRover's Avatar
Lol. No.. its a friend of mine in costume for a b rated horror movie..i forgot i put that up..i dont see it on the mobile version of the site
