Transmission crap on d2
Old Oct 29, 2019 | 08:30 PM
Esco4227's Avatar
6th Gear
Question Transmission crap on d2
Im in desperate need of help!!
I have replace trans on a 01 D2 (used) and still slipping and only takes reverse any thoughts what I should do?, fluids and filters have been replaced. could it be electrical? it doesnt take any gears and no weird noises.
Old Oct 30, 2019 | 04:05 AM
JUKE179r's Avatar
Are there any trouble codes?
Old Oct 30, 2019 | 08:20 AM
Esco4227's Avatar
6th Gear
Only thing that comes on is check engine.
Old Oct 30, 2019 | 08:27 AM
mollusc's Avatar
"check engine" isn't a code. that's a light. you need to get an obd2 device and whatever is stored in the various controls, probably including the transmission and braking systems.
Old Oct 30, 2019 | 09:02 AM
TimInNova's Avatar
At 144,000 miles my transmission worked perfectly. Like an idiot, I changed the filter and fluid, and it immediately began to slipping in 1st and reverse. The only solution was to replace it with a low mileage used one.
Moral of the story: If you have a high mileage transmission that is working fine, and you don't know if the fluid has ever been changed, don't change it!
Old Oct 30, 2019 | 09:18 AM
mollusc's Avatar
if you don't follow the fill procedure as outlined in the rave manual, your transmission won't be full and may slip. you have to do the final stage of filling with the engine running and close up the autobox before you shut it off.
Old Oct 30, 2019 | 12:34 PM
Esco4227's Avatar
6th Gear
I did use the instructions and filled it up as mentioned on manual.
Old Oct 30, 2019 | 04:09 PM
Esco4227's Avatar
6th Gear
is it possible that the ECU is bad? the one under driver seat?.
OffroadFrance
Dec 7, 2016 07:24 PM
Lyric
Oct 9, 2016 07:12 PM
OffroadFrance
Jan 3, 2015 01:15 PM
robertmirwin
Aug 22, 2013 10:31 AM
AK Rover
Jan 4, 2009 04:51 PM
